# Advanced Flow — Community Q&A (from Ask Me Anything 05-07-2022)
**URL:** <https://community.homey.app/t/advanced-flow-community-q-a-from-ask-me-anything-05-07-2022/65579>\
**Tags:** advancedflow\
**Created:** [July 5, 2022, 7:38pm UTC](https://community.homey.app/t/advanced-flow-community-q-a-from-ask-me-anything-05-07-2022/65579 "2022-07-05T19:38:10Z")\
**Showing post:** 229
**Post date:** [July 7, 2022, 8:21am UTC](https://community.homey.app/t/advanced-flow-community-q-a-from-ask-me-anything-05-07-2022/65579/229 "2022-07-07T08:21:10Z")
Hey @Emile,
In the AMA of 5-7-'22 at about 1:01:30, you are responding to a question about local variables.
I also have allready asked that question to you on the other forum-thread, but i will ask it again with a better decription and example.
Because at 1:01:50, **you say that the local tags can be modified**. I think you misspoke here, because as far as i know, tags cannot be changed: using for example the “Read as JSON and set PATH to […]” will create a new (modified) tag.
And this creates a “problem”.
But maybe i am missing something? In the AMA you talked about modifying the Tag.
**Is there a way of modifying a Tag within a flow (and thuse: not creating a new modified Tag)?**
So i will now try to explain what people, or at least i, mean bij local variables: **Scoped variables/tags that are mutable/modifiable and bound to the flow-execution.**
Why would you need this?
So i can set scoped variables based on if-then-else statements or assign default values in case there are errors.
Here is an example. In this example, there are three Text-Tags generated.
- The first one will stay the same
- The second and third are changed, buth there is no way to use those Tags in a recombining flowline.
 ![image](https://us1.discourse-cdn.com/flex025/uploads/athom/original/3X/4/2/42be5fb5fa7d20f7e890530330820e047830a6bc.png)
I have a lott of real use-cases. Like this example, after changing the Tag, i cannot recombine the three lines into one card, because it would not know which Tag to use.
 ![image](https://us1.discourse-cdn.com/flex025/uploads/athom/original/3X/b/e/beed074bdd84d42b9057ea62c26374d74b859beb.jpeg)
The only way to “modify” and “re-use” a value throughout the flow, is to put it in a variable, recombine the lines and re-read the variable.
Problem is, this is not scoped: running the flow multiple times paralel (fastly triggered for example) would change the variable during the flow execution for al flow-instances.
Here one more example of the pain to update variables throughout the flow, just to set default parameters, and still: this is not scoped and could give issues when executed paralel to each other.
 ![image](https://us1.discourse-cdn.com/flex025/uploads/athom/original/3X/0/2/022ab3ba186b229c926edef7b428a4974a12acf4.jpeg)
_[View the full topic](https://community.homey.app/t/advanced-flow-community-q-a-from-ask-me-anything-05-07-2022/65579)._
